[Qgis-developer] Processing: Raster calc errors (SAGA and
Paolo Cavallini cavallini at faunalia.it
Fri Jun 19 07:03:38 PDT 2015
Hi all,
we are getting errors in raster calculators (both SAGA and GDAL) on Win;
on OSX and Debian they are running fine. This happens with the training
manual no_data project.
Any hint?
All the best.
GDAL
Algorithm Raster calculator starting...
GDAL command:
gdal_calc --calc "A*3.28084" --format GTiff --type Float32 --NoDataValue
-9999 -A
C:/Users/user1/Desktop/QGIS_DATA/QGIS_data/processing/no_data/dem25.tif
--A_band 1 --outfile
C:\Users\user1\AppData\Local\Temp\processing\bd8916238fcb460a89efdfdbfd90a68e\OUTPUT.tif
GDAL command output:
File "C:\Program Files\QGISWI~1\bin\gdal_calc.py", line 49, in
import gdal
File "C:\Program
Files\QGISWI~1\apps\Python27\lib\site-packages\gdal.py", line 2, in
from osgeo.gdal import deprecation_warn
File "C:\Program
Files\QGISWI~1\apps\Python27\lib\site-packages\osgeo\__init__.py", line
21, in
_gdal = swig_import_helper()
File "C:\Program
17, in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: The specified module could not be found.
SAGA
Algorithm Shapes to grid starting...
grid_gridding "Shapes to Grid" -TARGET 0 -INPUT
"C:/Users/user1/Desktop/QGIS_DATA/QGIS_data/processing/extents/watersheds.shp"
-FIELD "NAME" -MULTIPLE 0 -LINE_TYPE 0 -GRID_TYPE 3 -USER_XMIN
262847.525725 -USER_XMAX 277845.525725 -USER_YMIN 4454026.0 -USER_YMAX
4464274.0 -USER_SIZE 2 -USER_GRID
"C:\Users\user1\AppData\Local\Temp\processing\d0830721f5464a56914b6296afe51aae\USERGRID.tif.sgrd"
io_gdal 1 -GRIDS
-FORMAT 4 -TYPE 0 -FILE
"C:\Users\user1\AppData\Local\Temp\processing\d0830721f5464a56914b6296afe51aae\USERGRID.tif"
C:\Program Files\QGISWI~1\bin>set SAGA=C:/Program Files/QGISWI~1/apps\saga
C:\Program Files\QGISWI~1\bin>set SAGA_MLB=C:/Program
Files/QGISWI~1/apps\saga\modules
C:\Program Files\QGISWI~1\bin>PATH=PATH;C:/Program
Files/QGISWI~1/apps\saga;C:/Program Files/QGISWI~1/apps\saga\modules
C:\Program Files\QGISWI~1\bin>saga_cmd grid_gridding "Shapes to Grid"
-TARGET 0 -INPUT
_____________________________________________
library path: C:\Program Files\QGISWI~1\apps\saga\modules\grid_gridding.dll
library name: Grid - Gridding
tool name : Shapes to Grid
author : O.Conrad (c) 2003
Load shapes:
C:/Users/user1/Desktop/QGIS_DATA/QGIS_data/processing/extents/watersheds.shp...
Parameters
Shapes: watersheds
Attribute: NAME
Output Values: attribute
Method for Multiple Values: first
Lines: thin
Polygon: cell
Preferred Target Grid Type: Floating Point (4 byte)
Target Grid: user defined
WARNING: selected attribute is not numeric; generating unique
identifiers instead.
C:\Program Files\QGISWI~1\bin>saga_cmd io_gdal 1 -GRIDS
69 loaded tool libraries (671 tools):
- climate_tools
- contrib_perego
- db_odbc
- db_pgsql
- docs_html
- docs_pdf
- garden_3d_viewer
- garden_fractals
- garden_games
- garden_learn_to_program
- garden_webservices
- grid_analysis
- grid_calculus
- grid_calculus_bsl
- grid_filter
- grid_gridding
- grid_spline
- grid_tools
- grid_visualisation
- imagery_classification
- imagery_opencv
- imagery_photogrammetry
- imagery_rga
- imagery_segmentation
- imagery_svm
- imagery_tools
- io_esri_e00
- io_gps
- io_grid
- io_grid_grib2
- io_grid_image
- io_shapes
- io_shapes_dxf
- io_shapes_las
- io_table
- io_virtual
- pj_georeference
- pj_geotrans
- pj_proj4
- pointcloud_tools
- pointcloud_viewer
- shapes_grid
- shapes_lines
- shapes_points
- shapes_polygons
- shapes_tools
- shapes_transect
- sim_cellular_automata
- sim_ecosystems_hugget
- sim_erosion
- sim_fire_spreading
- sim_hydrology
- sim_ihacres
- statistics_grid
- statistics_kriging
- statistics_points
- statistics_regression
- table_calculus
- table_tools
- ta_channels
- ta_compound
- ta_hydrology
- ta_lighting
- ta_morphometry
- ta_preprocessor
- ta_profiles
- ta_slope_stability
- tin_tools
- tin_viewer
type -h or --help for further information
Error: library
C:\Program Files\QGISWI~1\bin>exit
Converting outputs
Loading resulting layers
"C:\Users\user1\AppData\Local\Temp\processing\6f5a372602e34ddfa90dfcfd06ed11d2\USERGRID.tif.sgrd"
io_gdal 1 -GRIDS
"C:\Users\user1\AppData\Local\Temp\processing\6f5a372602e34ddfa90dfcfd06ed11d2\USERGRID.tif"
-TARGET 0 -INPUT
Load shapes:
Parameters
Shapes: watersheds
Attribute: NAME
Lines: thin
Polygon: cell
- climate_tools
- contrib_perego
- db_odbc
- db_pgsql
- docs_html
- docs_pdf
- garden_3d_viewer
- garden_fractals
- garden_games
- grid_analysis
- grid_calculus
- grid_calculus_bsl
- grid_filter
- grid_gridding
- grid_spline
- grid_tools
- imagery_opencv
- imagery_rga
- imagery_svm
- imagery_tools
- io_esri_e00
- io_gps
- io_grid
- io_grid_grib2
- io_grid_image
- io_shapes
- io_shapes_dxf
- io_shapes_las
- io_table
- io_virtual
- pj_georeference
- pj_geotrans
- pj_proj4
- pointcloud_tools
- pointcloud_viewer
- shapes_grid
- shapes_lines
- shapes_points
- shapes_polygons
- shapes_tools
- shapes_transect
- sim_erosion
- sim_hydrology
- sim_ihacres
- statistics_grid
- statistics_points
- table_calculus
- table_tools
- ta_channels
- ta_compound
- ta_hydrology
- ta_lighting
- ta_morphometry
- ta_preprocessor
- ta_profiles
- tin_tools
- tin_viewer
Error: library
Converting outputs
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
