[Qgis-developer] Qgis 91e44ea crash browsing GRASS 7 vector
Radim Blazek radim.blazek at gmail.com
Mon Jun 22 01:27:08 PDT 2015
I forgot to add that GRASS stable in OSGeo4W switched to
grass-7.0.1RC1-1 while qgis-dev-2.9.0-104 is still compiled with
grass-7.0.0-1 so when updating OSGeo4W select manually to keep
grass-7.0.0-1.
Radim
On Mon, Jun 22, 2015 at 10:23 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi Roy,
> the bug is fixed in OSGeo4w qgis-dev-2.9.0-104. Apart from browsing
> and displaying GRASS data you should be able to import data to GRASS
> in the browser with drag and drop. There are still some issues with
> import which I am trying to sort out:
> - vector import with more features is slow due to slow inserting to db
> (provider problem, v.in.ogr is fast)
> - temporary vector maps (polygons cleaning) are not deleted
> - animated import icon is missing, it means no layer icon = import
> running, for now on Windows
> Testing is welcome.
> Radim
> On Mon, Jun 15, 2015 at 10:03 AM, Roy <royroge at outlook.com> wrote:
>> Thank you for the info Radim!
>> Il 15/06/2015 08.25, Radim Blazek ha scritto:
>>> Hi Roy,
>>> this is known issue I haven't been able to fix so far. It has
>>> something to do with getting list of vector layers in thread. It seems
>>> to only happen with GRASS 7 on windows when Vect_cidx_get_* functions
>>> are used in thread (browser items are populated in threads). I have
>>> already double checked the code including relevant parts of GRASS
>>> vector lib without success.
>>> Radim
>>> On Thu, Jun 11, 2015 at 10:37 AM, Roy <royroge at outlook.com> wrote:
>>>> Hi,
>>>> i'm testing "QGIS desktop 2.9.0 with grass 7" and it crashes when
>>>> browsing
>>>> a grass 7 DB; (windows osgeo4w 32 bit)
>>>> i simply prepared a grass7 location and mapset, imported a vector
>>>> stopped grass and opened QGIS, with browser panel QGIS crashes
>>>> navigating to the imported vector,
>>>> if you confirm i can open a bug report, Roy
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
