[Qgis-developer] LayerBoard plugin - edit project layers properties while drinking coffea !
kimaidou kimaidou at gmail.com
Wed Jun 24 09:47:06 PDT 2015
I meant version 0.4, not 0.5 (too much excitment)
By the way, thanks to all who have given me ideas and helped me figure out
how to use some part of the QGIS api.
2015-06-24 18:45 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> I am excited to announce the new version 0.5 of my LayerBoard plugin I
> started during Nodebo Developper Meeting. It is still experimental but
> begins to have the features I was alway looking for when dealing with
> complex projects.
> Please test it and report issues, or propose Pull requests ! Any feedback
> welcome !
> Here is the copy of the README file visible in the github repository [1]
> ------------------------------8<-------------------------------
> This plugin helps to see and modify properties for vector and raster
> layers.
> It shows the layers in a table sheet, and the user can directly modify
> some properties such as layer name, title, abstract, minimum and maximum
> scales. To do so, double-click on a cell and modify the value. The modified
> cells are then drawn in yellow, and you can apply or discard the changes
> via the button under the table.
> Some properties can be changed on multiple layers at once, such as
> modifying spatial reference system and scale based visibility. To do so,
> select one or more layers in the vector or raster table, and use the right
> panel tools in the "Actions on Layers" tab, such as CRS or Max Scale, the
> click on the corresponding "Set" button.
> Some actions can be performed on multiple layers at once:
>    - create a spatial index ( done only on vector layers)
>    - save current style as default : it creates a QML file beside the
>    source file
> The information visible in the "Vector layers" or "Raster layers" tabs can
> be exported to a "Comma Separated Values" (CSV) text file via the button in
> the tab "Export" of the right panel
> When only one layers is selected, the tab "Layer style" in the right panel
> displays the current layers style, and you can change the style directly
> for the selected layer via the "Apply" button. This is only available for
> vector layers.
> IMPORTANT : the changes are made in the current project, and will be saved
> only if you save the project.
> Kimaidou (Michaël Douchin)
> [1] https://github.com/3liz/QgisLayerBoardPlugin/#layer-board-plugin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150624/735556f5/attachment-0001.html>
