[Qgis-developer] QGIS server (broken?) logging
Alessandro Pasotti apasotti at gmail.com
Thu Mar 5 05:21:24 PST 2015
Hi Gino!
I can also use standard python logging appending to the qgis log file
and it works fine, anyway the problem is partially solved, you have to
use QGIS_SERVER_LOG_FILE env var instead of QGIS_LOG_FILE.
I'm still convinced that logging should be enabled by default and
should write to stderr and hence go into the web server error log but
I can live with a custom configurable file.
2015-03-05 11:33 GMT+01:00 Luigi Pirelli <luipir at gmail.com>:
> On 4 March 2015 at 21:38, Alessandro Pasotti <apasotti at gmail.com> wrote:
>> QgsMessageLog
> http://osgeo-org.1560.x6.nabble.com/how-to-get-debugging-messages-td4471936.html
> QgsMessageLog is a QgsDebugMsg wrapper emitting signal (most of them
> intercepted by QGIS log message panel)
> QgsDebugMsg (is a define on QgsLogger) write messages only if compiled in Debug
> regards, Luigi Pirelli
> p.s. avoiding debugging, you can create a new QGIS server plugin that
> intercept QgsMessageLog signal to log them ;)
Alessandro Pasotti
w3:   www.itopen.it
