[Qgis-developer] Qgis-developer] Make error - QGIS Latest (2.6.0) and QGIS 2.8.1 too
Jérôme Lefèvre jerome.lefevre at ird.fr
Sun Mar 22 15:24:19 PDT 2015
Mark,
Many thanks to confirm that we need python 2.7 with QGIS 2.8.1 and 2.6.
I will begin to prepare 10 large cups of coffee ...:)
Cheers,
Jerome
Mark Wynter a écrit :
> Hi Jerome
> You will need to compile Qgis against Python 2.7 - which you need to install from source. Not yum.
> You then need to make sure you have the latest bindings installed.
> add the KDE repo - it has many of the required libs in there.
> This is my QGIS setup
> QGIS version    2.8.1-Wien    QGIS code revision    exported
> Compiled against Qt    4.8.5    Running against Qt    4.8.5
> Compiled against GDAL/OGR    1.11.1    Running against GDAL/OGR    1.11.1
> Compiled against GEOS    3.4.2-CAPI-1.8.2    Running against GEOS    3.4.2-CAPI-1.8.2 r3921
> PostgreSQL Client Version    9.3.5    SpatiaLite Version    2.4.0
> QWT Version    6.0.1    PROJ.4 Version    480
> QScintilla2 Version    2.8.4
>> Hi,
>> I manage to compile without error 2.8.1 on Centos 6.5 with python
>> 2.6.6.
>> Please see my notes here :
>> http://gis.stackexchange.com/questions/139693/half-solved-compilation-of-qgis-2-8-against-grass-7-from-source-with-centos6-5
>> (also repeated later below)
>> But at the runtime, I have the same error like Mark Wynter, described
>> in
>> http://lists.osgeo.org/pipermail/qgis-developer/2014-November/035397.html
>> a pop-up with "Couldn't load plugin 'processing'
>> Traceback (most recent call last):
>> File "/usr/local/share/qgis/python/qgis/utils.py", line 185, in
>> loadPlugin
