[Qgis-developer] [GRASS-dev] QGIS GRASS Plugin Upgrade Crowdfunding
Radim Blazek radim.blazek at gmail.com
Tue Mar 24 01:40:49 PDT 2015
Hi Soeren,
thanks for your reaction. I remember we already discussed the
possibility to move to Python.
On Mon, Mar 23, 2015 at 9:19 PM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi Radim,
> this is a beautiful idea and i hope you will get plenty of funds.
> I have some questions regarding the implementation, since this is not
> mentioned in the project description:
> Do you plan to implement the plugin in C++ only, or will you try to
> combine C++ (data provider) and Python (all the rest)? The reason i am
> asking is, that using Python for the user interaction, module calling,
> vector editing and mapset/location handling would allow us GRASS
> developer to provide possible improvements and bugfixes for the plugin
> more easily. For example, the time series handling [1] in GRASS GIS is
> mainly implemented in Python and provides a Python API that could be
> used in the QGIS GRASS Plugin to implement time series analysis
> support.
> Using the QGIS Python plugin approach will reduce the need for
> compilation, which allows much faster development of modifications and
> bugfix testing.
I completely agree that Python would be better, the advantages of
Python are obvious and that would be definitely my choice if I had to
start from scratch. Un(fortunately) the GRASS plugin + qgsgrassgislib
have already 22500 lines of C++ so porting to Python is not an option
and mixing C++ in single plugin either (as far to my knowledge).
Are there functions in time series implementation which need to be
called directly from the plugin or everything may be done just calling
t.rast.* modules?
Radim
> The data provider and vector editing helper classes must be of course
> implemented in C++ and should stay in the QGIS source tree.
> Best regards
> Soeren
> [1] http://ifgi.uni-muenster.de/~epebe_01/tgrass.pdf
> Btw: Otto Dassau and i mentioned your crowd funding idea at the
> FOSSGIS in Germany two weeks ago. It is on Youtube[2] but only in
> German.
> [2] https://www.youtube.com/watch?v=rxmPbh2igmM&t=1407
> 2015-03-23 19:56 GMT+01:00 Radim Blazek <radim.blazek at gmail.com>:
>> Hi all,
>> I have finally launched the crowdfunding campaign to support the GRASS
>> plugin upgrade. Briefly, it covers upgrade to GRASS 7, browser
>> integration, drag-and-drop import and new vector editing. All the
>> details are available here:
>>     http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
>> Please propagate this info to all relevant channels, national mailing lists etc.
>> Radim
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
