[Qgis-developer] wrong attribute values for postgis data in Feature attribute form
Raymond Nijssen r.nijssen at terglobo.nl
Thu Mar 26 02:57:42 PDT 2015
Thanks Regis, that was exactly the issue. The (boolean!) field
'inonderzoek' was used as a key. When I change that to 'gid' in the Add
PostGIS Table dialog, everything works correctly.
Can anyone tell me why QGIS picks that boolean field for most of my
tables? Can I change that behaviour by changing my database structure?
http://terglobo.nl/downloads/qgis_add_postgis_table_wrong_key.png
And how can the identify results be correct anyway?
Tnx,
Raymond
dbname='bag' host=localhost port=5432 user='postgres' sslmode=disable
key='inonderzoek' estimatedmetadata=true srid=28992 type=POLYGON
table="bagactueel"."pandactueelbestaand" (geovlak) sql=
On 26-03-15 10:34, Régis Haubourg wrote:
> Hi, I have seen such troubles when the choosen primary key from qgis side is
> not unique .
> Symptoms: selecting one feature select severals unrelated features of the
> same layer. relation with attributes is broken also.
> Can you check in your layer's definition (general tab of layer properties)
> if you choose gid field as key, and check if it is really unique in postgis?
> Cheers
> Régis
> View this message in context: http://osgeo-org.1560.x6.nabble.com/wrong-attribute-values-for-postgis-data-in-Feature-attribute-form-tp5195518p5195523.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
