[Qgis-developer] Rendering active map symbol as QPixmap
Andrew McClure andrew at southweb.co.nz
Thu May 7 22:00:46 PDT 2015
Awesome,
Thanks Nathan!
On 8/05/2015, at 10:34 am, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Andrew,
> This is how I did it with Roam to get all the legend items for the layer:
> items = layer.rendererV2().legendSymbologyItems(ICON_SIZE)
> That will give you a list of:Text - Icon pairs
> if you are using the rule base renderer you get can the symbol for the rule and paint that into a pixmap, however note that one feature can have many symbols so you will have to use the method that returns a list for all the symbols.
> Depending on what you are doing  legendSymbologyItems might give you what you need without extra work.
> - Nathan
> On Fri, 8 May 2015 at 07:00 Andrew McClure <andrew at southweb.co.nz> wrote:
> Any takers for this one? I'd like to render the active symbol for a layer as a QPixmap in a dialog.
> I have got this far:
>        s =  layer().rendererV2()
>        key = s.rootRule().findRuleByKey(s.rootRule().ruleKey())
> This tells me the active rule key to be rendered but how to get the image data?
> Perhaps I am barking up the wrong tree here?
> Thanks
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150508/4e605c38/attachment.html>
