[Qgis-developer] [QGIS] New processing validity checker before feature freeze
Luigi Pirelli luipir at gmail.com
Mon May 25 05:35:02 PDT 2015
Hi Arnoud,
if it's possibile, try to add the documentation of the algorithm
commiting in the QGIS-Documentation.
did you check that travisCI has failed compilation? check if it
related with geometry update by Marco or depends on your modification
(I don't think so)
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 25 May 2015 at 11:39, Arnaud Morvan <arnaud.morvan at camptocamp.com> wrote:
> Hello,
> I've created a new processing algorithm to check geometry validity at the
> hackfest.
> (It is a fTools feature which was missing in processing)
> Here is the pull request: https://github.com/qgis/QGIS/pull/2064
> I'd like it to be merge before feature freeze.
> I think everything is OK to merge, comments are welcome anyway.
> I've just rebased it on last successfully tested commit from master to avoid
> conflicts.
> Best regards.
> Arnaud
> Qgis-developer mailing list
