[Qgis-developer] PluginBuilder writes a wrong import inside .py
    Worth Lutz
    wal3 at mindspring.com
    Tue Nov  3 06:55:49 PST 2015
This is not fixed.
Some background info:
http://gis.stackexchange.com/questions/139625/qgis-plugin-problems-importing-resources-resources-rc-file-plugin-doasnt-l/155599#155599
This is a problem with  "uic.loadUiType".
I have have determined that if you save your "ui" file in QT designer
with the resources open after you have added a resource, you get this error.
This is because  QT designer adds
    <resources>
       <include location="resources.qrc"/>
    </resources>
at the end of the file and this causes uic.loadUiType to look for a
"resources_rc" as "_rc" is a default suffix.
I think closing the resource browser before saving the "ui" file in QT
Designer will keep this added resources lines from being added to the
end of the "ui" file.
*Worth Lutz*
On 11/3/2015 6:03 AM, Richard Duivenvoorde wrote:
> On 03-11-15 11:45, Anita Graser wrote:
>> On Tue, Nov 3, 2015 at 10:49 AM, Geo DrinX <geodrinx at gmail.com
>> <mailto:geodrinx at gmail.com>> wrote:
>>      Hello all,
>>      probably you just know, but I found that "PluginBuilder"  plugin for
>>      QGIS  writes at line 26  of the main  .py  file the following code:
>>      import resources
>>      I think this is wrong,  because in run it returns a python error.
>>      The correct code is:
>>      import resources_rc
>> Hi Roberto,
>> Afaik, the plugin builder code is not wrong. You just have to adjust the
>> name of the output file when compiling the resources.
>> Best wishes,
>> Anita
> Hi Roberto,
> I've had this issue also some time ago, but according to Gary it should
> be fixed:
> https://github.com/g-sherman/Qgis-Plugin-Builder/issues/34
> Note off course that plugins build with an older version of the builder
> still will have the problem.
> If you still have this problem with a current plugin, please report back
> at the issuelist at Github
> Regards,
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151103/95df14d1/attachment.html>
