[Qgis-developer] TypeError: C++ type 'QgsFeatureIds' is not supported as a signal argument type
//./\\-/_.\\ m431m at tutanota.com
Fri Nov 13 00:18:53 PST 2015
Hi developers,
With OSX, QGIS 2.8.3 and higher, I found an error  what appears to be a
regression (perhaps).
And with QGIS 2.12, the problem persists.
So, if you want to try to reproduce the error, open python console and try
(with any active layer on editing mode):
>>> layer = iface.activeLayer()
>>> def listener(s, l):
>>>      print s, l
Then,
>>> layer.committedFeaturesRemoved.connect(listener)
Or
>>> from PyQt4.QtCore import QObject
>>> from PyQt4.QtCore import SIGNAL
>>> QObject.connect(layer, SIGNAL(r"committedFeaturesRemoved(QString,
>>> QgsFeatureIds )"), listener)
It returns this error: “TypeError: C++ type 'QgsFeatureIds' is not supported
as a signal argument type”
My English is so bad that nobody wants to answer me?
m431m
1. Oct 2015 16:22 de m431m at tutanota.com:
>     Hi,
> No Mac user able to reproduce the error? Am i the only one?
> m431m
> 25. Sep 2015 13:50 de > m431m at tutanota.com> :
>>     >> Hi QGIS developers!
>> I got strange error with the 'commitedFeaturesRemoved' signal.
>> See: >>
>> http://www.qgis.org/api/classQgsVectorLayer.html#a520550b45603ed20d593b1050768bd97
>> I try on python console (with any active layer on editing mode):
>> >>> def listener(s, l):
>> >>>     print s, l
>> It returns `TypeError: C++ type 'QgsFeatureIds' is not supported as a
>> signal argument type`
>> Now replace `layer.commitedFeaturesRemoved.connect(listener)`by:
>> >>> QObject.disconnect(layer, SIGNAL(r"committedFeaturesRemoved()"),
>> listener)
>> No error, but it returns `False`.
>> If I delete some features and switch off editing mode, it returns nothing!
>> No print! The signal doesn't work(?)
>> After exchanging a few message with some people on irc #qgis, the error
>> only appears with latest QGIS version on OSX10.10.5. (it works well with
>> 2.8.2).
>> Maybe someone that has approached the same problem... and solved it?
>> m431m
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151113/960f44df/attachment.html>
