[Qgis-developer] Quick fixes and error communication for ftools
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Nov 24 07:36:07 PST 2015
Hi all
I had a detailed look with the debugger at what happens in the different
versions. It turned out fTools does indeed handle geometry collections,
but assumed a geometry collection has wkb type 'unknown' (which was true
<= 2.8, but now geometry collections are not unknown anymore). Commit
https://github.com/qgis/QGIS/commit/594fafe73b80d91d94b962c2e51aea0b0168a08a
should solve the issue and bring back the old behaviour.
Regards,
Marco
On 24.11.2015 11:29, Marco Hugentobler wrote:
> On 24.11.2015 11:13, Matthias Kuhn wrote:
>> Hi Marco
>> On 11/24/2015 11:01 AM, Marco Hugentobler wrote:
>>> Hi Alessandro, Matthias
>>> >Is there no requirement for multi types?
>>> Afaik, the problem for f-tools are not the multi types, but only the
>>> geometry collections (containing geometries with different shape
>>> type). In my experience, if geos returns a geometry collection, it
>>> usually contains one 'expected' geometry and the others are slivers
>>> (@strk, please correct me if wrong).
>> I was mostly thinking about collections that contain a multitype with
>> several parts which are not considered slivers. This seems to be a
>> very valid scenario.
> It is, but it was also not handled by f-tools <= 2.8.
>>> >Based on what indicator should be chosen what to extract? Try
>>> polygons first, if there are none try lines, if there are none take
>>> points?
>>> One possibility would be to pass the expected shapetype (Point /
>>> Line / Polygon) to the function and take the best candidate (e.g.
>>> longest line, largest polygon area).
>> Before the geometry changes, the algorithms were able to provide the
>> results without this additional information. How was that done?
> Not sure. Maybe the logic in the geos -> QgsGeometry conversion
> handled the collections differently.
> Regards,
> Marco
>>> >How much effort (in time) do you think is required to implement
>>> this fix?
>>> Difficult to estimate. It seems straightforward to implement the
>>> extraction function. Then it needs to be called by the f-tools
>>> internally and be tested with a few examples. If unit tests are
>>> required (as mentioned by Alessandro), this seems to be the most
>>> time consuming task to me.
>> Unit Tests for processing are on my todo list anyway (I think as a
>> psc member you should have voted for that ;) )
>> Matthias
>>> Regards,
>>> Marco
>>> On 24.11.2015 10:42, Matthias Kuhn wrote:
>>>> Hi Marco
>>>> Good to have your feedback, you probably know the problem best.
>>>> On 11/24/2015 09:28 AM, Marco Hugentobler wrote:
>>>>> Hi
>>>>> >ad issue 1: update fTools to warn users when some features cause
>>>>> problems
>>>>> >ad issue 2: quick fix fTools to convert geometry collections to
>>>>> single geometry types
>>>>> A function that takes a geometry type and extracts the longest
>>>>> line / the largest polygon / the first point from the geometry
>>>>> collection should be straightforward to do.
>>>> points?
>>>>> >These fixes/updates would be made available as fTools updates via
>>>>> the plugin installer asap
>>>>> If the fix does not take too long, we probably don't need a
>>>>> warning at all.
>>>> this fix?
>>>> Regards,
>>>> Matthias
>>>>> Regards,
>>>>> Marco
>>>>> On 23.11.2015 21:35, Anita Graser wrote:
>>>>>> Hi,
>>>>>> If you are following the psc list, you've probably seen the
>>>>>> thread discussing current shortcomings of ftools
>>>>>> (http://lists.osgeo.org/pipermail/qgis-psc/2015-November/003623.html)
>>>>>> In short, the key issues are:
>>>>>> 1. When ftools encounter issues with certain features, warning
>>>>>> messages get written to the log but this is largely hidden from
>>>>>> users since they would actively have to actively monitor the log.
>>>>>> The problematic features are then missing from the results but
>>>>>> this is not always obvious.
>>>>>> 2. The above issue is more common now (since 2.10) since
>>>>>> underlying libraries more often (and correctly so) produce
>>>>>> geometry collections as outputs. These geometry collections are
>>>>>> not handled well by the current ftools code which is much older.
>>>>>> To address these issues, the following suggestions have been made
>>>>>> so far:
>>>>>> problems
>>>>>> For the warnings, there's already a first PR draft
>>>>>> https://github.com/qgis/QGIS/pull/2432 which needs to be fleshed
>>>>>> out.
>>>>>> the plugin installer asap.
>>>>>> If you have ideas how to handle this efficiently or have already
>>>>>> implemented code that addresses similar issues, let us know.
>>>>>> It would be good to have a quick discussion in order to be able
>>>>>> to provide improvements fast.
>>>>>> Best wishes,
>>>>>> Anita
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Dr. Marco Hugentobler
>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
>>>>> Technical Advisor QGIS Project Steering Committee
>>>> Matthias Kuhn
>>>> OPENGIS.ch -https://www.opengis.ch
>>>> Spatial • (Q)GIS • PostGIS • Open Source
>> Matthias Kuhn
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151124/5c8e8715/attachment-0001.html>
