[Qgis-developer] Tool to pick up linear referencing measure from mouse
Luigi Pirelli
luipir at gmail.com
Tue Nov 24 14:48:26 PST 2015
alessandro Pasotti has a pull request that probably is what you are looking
for
https://github.com/qgis/QGIS/pull/2498
Regards
On Tuesday, 24 November 2015, Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr> wrote:
> Well, thanks Nyall, Radim and Pierre for your lights !
> Nyall Dawson wrote
> >> I think that now (>=2.8), when QGIS geometry supports M (measure), the
> >> measure calculated for the nearest point on the identified line
> >> could/should be added to derived attributes in standard identify
> >> results.
> > And as of 2 days ago, it does: ;)
> https://github.com/qgis/QGIS/commit/1f0d24a0c7a6555ced117ecfc08a73afb1f31b46
> > Nyall
> I suppose that means that in 2.14, I'll be able to make my own tool calling
> identify classes to get vertex measure. So good!
> Radim, do you have plans to extend LRS in 2016? If you have sponsors
> looking
> for co-funders, I would be interested in having it work with existing
> M-geometries, and have tools to generate events by picking locations on the
> map.
> Last question now :)
> I need to make an edit form, with inline with some attributes (measure, or
> x
> / y) that user shall use to go picking those data from the canvas. Behind
> the button, I need to code some behaviour, like target layer, snapping
> options, fields or geometry information to catch, and of course destination
> field.
> Is this possible with a python init script, without any plugin?
> If so, that allows me to distribute project + ui file + .py and have it
> work
> with no plugin install or additional configuration.
> Any snippet to point me in the right direction? (When done, I will submit
> it to pyqgis cookbook, this would be great to share).
> All the best
> Régis
> http://osgeo-org.1560.x6.nabble.com/Tool-to-pick-up-linear-referencing-measure-from-mouse-tp5238110p5238358.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <javascript:;>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151124/40137a03/attachment.html>
