[Qgis-developer] grass module don't appear
Giovanni Manghi giovanni.manghi at gmail.com
Wed Nov 25 12:35:00 PST 2015
> Then I searched for r.mapcalculator, which was present in the old processing toolbox. I didn't find it
> in the grass7 processing modules list. Although the grass7 stand alone has r.mapcalc (not r.mapcalculator),
> in the grass7 processing toolbox neither r.mapcalculator nor r.mapcalc are present.
> I wonder if is it possible to add grass7 module thus I can insert r.null, then I would like to know if
> I can put in r.mapcalculator or r.mapcalc at least.
In Processing GRASS r.mapcalc can't be added, unless doing some work, see
http://hub.qgis.org/issues/6894
on the other hand in GRASS 7 r.mapcalculator is not available, so it
is not also in Processing.
cheers
-- g --
