[Qgis-developer] OpenlayersPlugin QGIS
Marica Landini bulma at ferrara.linux.it
Fri Oct 2 01:02:08 PDT 2015
Thanks you it works fine!
Regards
Marica
On Thu, Oct 1, 2015 at 2:50 PM, Enrico Ferreguti <enricofer at gmail.com>
wrote:
> starting by saying that I never experienced problems with Openlayers
> plugin behind proxy, anyway I resolved all my proxy issues (user,
> passwords, subnet exclusions ...) using Qgis own network manager instead of
> creating a new one so you can try to remove the lines from 48 to 51 of
> openlayers_layer.py file and replace the row 52:
> self.setNetworkAccessManager(self.__manager)
> with the following:
> self.setNetworkAccessManager(QgsNetworkAccessManager.instance())
> I just try and it goes but I don't know if it resolvs your issue.
> Regards
> Enrico Ferreguti
> 2015-10-01 12:32 GMT+02:00 Marica Landini <bulma at ferrara.linux.it>:
>> Sorry,
>> I have this problem with 2.8 and 2.10.1 QGIS version (64bit)
>> I have not tried other versions
>> and I use Win7.
>> I really appreciate any help you can provide.
>> Marica
>> On Thu, Oct 1, 2015 at 12:24 PM, Marica Landini <bulma at ferrara.linux.it>
>> wrote:
>>> Hi,
>>> I need to use OpenlayersPlugin QGIS behind proxy network.
>>> But I need to use defaultproxy settings configuration.
>>> QGIS works fine with this defaultproxy settings
>>> (also connection to wms/etc...
>>> reading plugin list and download it).
>>> But (with the defaultproxy settings) I can not work with
>>> that return:
>>> TypeError: unable to convert a QVariant of type 10 to a QMetaType of
>>> type 2
>>> I can instead use this plugin with http proxy and setting manually the
>>> configuration (Settings->Options->Network)
>>> I have tryed to modify OpenlayersPlugin tool_network.py
>>> commenting setHostName/setPort/setUser/setPassword
>>> and using
>>> QNetworkProxy.setApplicationProxy(QNetworkProxy(QNetworkProxy.DefaultProxy))
>>> obvious I do not get TypeError,
>>> but the plugin not work properly (e.g. I do not get OSM layer).
>>> How can I resolve this problem?
>>> There is another plugin that works with default (machine) proxy settings?
>>> (apologies for my english)...
>>> Cheers,
>>> Marica
>>> Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg
>>> Preferisco formati liberi.
>>> Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
>>> I prefer free formats.
>>> http://it.wikipedia.org/wiki/Formato_aperto
>>> http://en.wikipedia.org/wiki/Open_format
>>> Marica Landini
>> Marica Landini
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marica Landini
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151002/e328c3dc/attachment-0001.html>
