[Qgis-developer] Latest QGIS dev (2.11) won't compile using Qt5 libraries
Mathieu Pellerin nirvn.asia at gmail.com
Sun Oct 4 01:31:03 PDT 2015
Ok, let me try the PR.
As for the directive, yes, I'm using an empty build directory with the
following cmake command: cmake -DENABLE_QT5=TRUE -DWITH_BINDINGS=FALSE
-DWITH_INTERNAL_QWTPOLAR=FALSE
On Sun, Oct 4, 2015 at 3:28 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> On 10/04/2015 09:53 AM, Mathieu Pellerin wrote:
> Larry, Matthias, is there an easy fix that can be applied so 2.12 can ship
> and be qt5-compatible?
> Can you check this and report back:
> https://github.com/qgis/QGIS/pull/2347
> Oh btw, ubuntu now has qt5 packages for scintilla, qwt, and qca but the
> cmake process picks the qt4 versions when cmaking with enable_qt5
> Can you confirm the first call to cmake on an empty build directory
> already included the ENABLE_QT5 directive?
> Matthias
> M
> On 4 Oct 2015 14:43, "Matthias Kuhn" < <matthias at opengis.ch>
>> Hi Mathieu,
>> On 10/04/2015 03:55 AM, Mathieu Pellerin wrote:
>> Greetings,
>> (Note: it's the first time I'm trying to compile QGIS using Qt5, so the
>> problem might be the user here ;) )
>> Using the current master (what will become 2.12), I fail to successfully
>> compile a build using Qt5 libraries. The make process crashes when trying
>> to compile qgsauthcertutils.cpp with the following error:
>> /home/webmaster/dev/cpp/QGIS/src/core/auth/qgsauthcertutils.cpp: In
>> static member function ‘static QMap<QString, QList<QSslCertificate> >
>> QgsAuthCertUtils::certsGroupedByOrg(QList<QSslCertificate>)’:
>> /home/webmaster/dev/cpp/QGIS/src/core/auth/qgsauthcertutils.cpp:64:68:
>> error: no matching function for call to ‘QString::QString(QStringList)’
>>      QString org( cert.subjectInfo( QSslCertificate::Organization ) );
>> In file included from
>> /usr/include/x86_64-linux-gnu/qt5/QtCore/QString:1:0,
>>                  from /usr/include/Qca-qt5/QtCrypto/qca_core.h:36,
>>                  from /usr/include/Qca-qt5/QtCrypto/qca.h:36,
>>                  from /usr/include/Qca-qt5/QtCrypto/QtCrypto:1,
>>                  from
>> /home/webmaster/dev/cpp/QGIS/src/core/auth/qgsauthcertutils.h:21,
>>                  from
>> /home/webmaster/dev/cpp/QGIS/src/core/auth/qgsauthcertutils.cpp:17:
>> Question: is it the case that ATM master does not compile using Qt5
>> anymore? Or is there something I'm missing here?
>> Yes, it looks like the authentication system is incompatible with Qt5. In
>> particular this API change:
>> > QSslCertificate::subjectInfo() and QSslCertificate::issuerInfo() now
>> return a QStringList instead of a QString
>> > It's pretty common for a certificate to contain more than entry of a
>> specific type, but in Qt 4 the API only let you access the first one.
>> https://blogs.kde.org/2012/04/14/whats-new-qt-5-ssl
>> Cheers
>> Matthias
>> Thanks for the help.
>> Math
>> P.S. the reason why I'm trying to get a functioning Qt5-based build is
>> that I've ran into a problem with Burmese character encoding that's fixed
>> under Qt5, due to its use of harfbuzz-ng. So, one additional motivation to
>> to the upgrade eventually :)
>> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151004/877c6095/attachment-0001.html>
