[Qgis-developer] Default fill/outline color for svg symbols
Nyall Dawson nyall.dawson at gmail.com
Sat Oct 10 04:21:28 PDT 2015
On 10 October 2015 at 21:02, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> Hi all,
> I'm currently working on fixing some issues with svg symbol rendering.
> I'm wondering what everyone's thoughts regarding
> http://hub.qgis.org/issues/10908 is?
> Situation is:
> - default fill color of svg marker symbols is white, outline is black.
> - Up until 5 minutes ago, there was a bug regarding outline widths for
> svg images. This meant that the width had to be ridiculously large to
> be visible (eg 10-20x larger than desired). After fixing this bug the
> outline is now visible in the svg image selector, so possibly that's
> #10908 fixed.  BUT - now I think the default svg marker width is much
> too large (1 mm). I think this should be something more like 0.2 mm.
> So I need some feedback. What should be the CORRECT default SVG marker
> fill and border color, and border width?
> (Personally, I'm leaning toward leaving it as white fill, black
> outline, 0.2mm width.)
Argh, forgot one other related question:
At the moment, changing the symbol resets the full and outline color
to match the default fill/outline set in the SVG symbol. I'd like to
change this behaviour so that whatever user-set fill/outline color is
kept when changing the source svg symbol. Any objections?
Nyall
> Nyall
