[Qgis-developer] error when compiling with grass7
Radim Blazek radim.blazek at gmail.com
Mon Oct 12 03:16:41 PDT 2015
On Mon, Oct 12, 2015 at 12:02 PM, matteo <matteo.ghetta at gmail.com> wrote:
> Hi Radim,
> well in the src/providers/grass folder I have the following directories:
> 7 CMakeFiles
If you run 'make' in src/providers/grass/7 it compiles without error?
It should either build target qgisgrass7 (libqgisgrass7.so) or give an
error.
Radim
> and actually in output/lib/qgis/plugins/ there is not any
> libqgisgrass7.so file
> I try to create another build directory in the repo and compile again
> from scratch but I receive the same error..
> Thanks
> Matteo
