[Qgis-developer] Crash Dump 2.11 with user defined expressions
Alexandre Neto senhor.neto at gmail.com
Mon Oct 12 07:58:43 PDT 2015
Hello all,
I'm having Crash Dumps in current master, on windows 7 64 bits. After a few
tests and some .qgis2 cleaning I realized it has something to do with
expression functions created by user.
The attached file makes qgis crash dump, if you try to open the expressions
dialog.
It works in QGIS 2.8.3 tho.
Did not test on Linux.
Best regards,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151012/b5e29877/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151012/b5e29877/attachment.obj>
