[Qgis-developer] How should the dissolve tool in Processing work?
Bernhard Ströbl bernhard.stroebl at jena.de
Mon Oct 19 06:36:58 PDT 2015
hi Alexandre
Am 19.10.2015 um 14:21 schrieb Alexandre Neto:
> Hi,
> I think this is a bit of feature request, but I would say it should be
> possible to have some control over the remaining attributes. Trimming
> all attributes seems poor to me, but keeping the attributes with "first
> attribute found" without informing the user it's also not good.
>         Harrissou Santanna mentioned the Dissolve with Stats Plugin.
>         That's the way ArgGIS does it, you can have stats or even
>         join/concatenate of the non-dissolved attributes.
Could you elaborate on that? Does it do stats for every suitable field?
This would multiply the number of fields in the output, besides there
could be problems with field names (dbf has 10 signs if I recall
correctly) or can you choose the which field to run the stats on? How
many fields?
Bernhard
> Victor Olaya <volayaf at gmail.com <mailto:volayaf at gmail.com>> escreveu no
> dia seg, 19/10/2015 às 12:15:
>     Hi Anita
>     nice discussion you bring up
>     Shouldn't it behave like the ftools dissolve tool currently does?
>     2015-10-19 13:10 GMT+02:00 Anita Graser <anitagraser at gmx.at
>     <mailto:anitagraser at gmx.at>>:
>      > Hi,
>      > I'm asking for your input on a discussion concerning the
>     Processing dissolve
>      > tool here: http://hub.qgis.org/issues/13502
>      > How should it ideally work, i.e. how should the attributes of the
>     dissolved
>      > features be treated? Given the current Processing limitations,
>     how should
>      > the options look like?
>      > Thanks in advance! Best wishes
>      > Anita
>      > _______________________________________________
>      > Qgis-developer mailing list
>      > Qgis-developer at lists.osgeo.org
>     <mailto:Qgis-developer at lists.osgeo.org>
>      > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
Am Anger 26
07743 Jena
Tel.: 03641 49- 5190
E-Mail: bernhard.stroebl at jena.de
Internet: www.kij.de
Eigenbetrieb der Stadt Jena
Werkleiter: Karl-Hermann Kliewe
__________ Information from ESET Mail Security, version of virus signature database 12430 (20151019) __________
The message was checked by ESET Mail Security.
http://www.eset.com
