[Qgis-developer] Possible error in Processing > SAGA > Hypsometry on OSX
Paolo Cavallini cavallini at faunalia.it
Sun Oct 25 01:07:51 PDT 2015
Il 25/10/2015 09:04, Victor Olaya ha scritto:
> can you send the log details?
Prepare algorithm: SAGAHYPSOMETRY_1
Running Hypsometry [2/2]
Parameters: ELEVATION
=/var/folders/2g/4bwvs38x2fn_84zv4lr4cx1m0000gn/T/processing/5a79996e7ccb4f8cb42047c0db184241/OUTPUT.sdat,
COUNT =100, SORTING =0, METHOD =0, BZRANGE =True, ZRANGE_MIN =0,
ZRANGE_MAX =1000
ta_morphometry "Hypsometry" -ELEVATION
"/var/folders/2g/4bwvs38x2fn_84zv4lr4cx1m0000gn/T/processing/5a79996e7ccb4f8cb42047c0db184241/OUTPUT.sgrd"
-COUNT 100 -SORTING 0 -METHOD 0 -BZRANGE true -ZRANGE_MIN 0 -ZRANGE_MAX
1000 -TABLE
"/var/folders/2g/4bwvs38x2fn_84zv4lr4cx1m0000gn/T/processing/f7286094ea294d77911b31f56ec52f35/TABLEALGSAGAHYPSOMETRY1.csv"
____________________________
SAGA Version: 2.1.4
library path: /Applications/QGIS.app/Contents/MacOS/lib/saga/
library name: libta_morphometry
library : Morphometry
tool : Hypsometry
author : (c) 2001 by O.Conrad
Load grid:
/var/folders/2g/4bwvs38x2fn_84zv4lr4cx1m0000gn/T/processing/5a79996e7ccb4f8cb42047c0db184241/OUTPUT.sgrd...
Parameters
Grid system: 25; 213x 181y; 262884.025725x 4454062.5y
Elevation: OUTPUT
Hypsometry: Hypsometry
Number of Classes: 100
Sort: up
Classification Constant: height
Use Z-Range: yes
Z-Range: [0.000000] - [1000.000000]
Create index: OUTPUT
Failed
Error executing algorithm Hypsometry local variable 'prjFile' referenced
before assignment See log for more details
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
