[Qgis-developer] QGIS 2.12 New Geometry Checker Plugin crash
Sandro Mani manisandro at gmail.com
Fri Oct 30 03:47:08 PDT 2015
On 30.10.2015 10:54, m roy wrote:
> Il 29/10/2015 11.08, Sandro Mani ha scritto:
>> On 29.10.2015 09:24, m roy wrote:
>>> If with test suite you mean steps to reproduce the crash:
>>> 100% crash
>> Thanks for the detailed steps, I've fixed this in my
>> geom_checker_fixes branch [1] (which I periodically push into master).
> Will it be possible to update the plugin or is it mandatory to recompile
> QGIS as a whole to test the bug fix?
In short, you'll need to recompile the entire QGIS. But if you then keep
the sources and build directory, subsequent builds will be incremental,
hence much quicker.
