[Qgis-developer] translate shortcuts
jawensi jawensi at gmail.com
Mon Sep 7 07:50:38 PDT 2015
Hello.
I want to translate a menu name which has a shortcuts when Alt key is
pressed.
/self.templMenu.setTitle(self.tr('&Templates'))/
The letter of shortcuts is defined with symbol '&'. In my example the menu
name is 'templates' and when 'Alt + t' is pressed the menu is opened.
When I write the 'my_plugin_es.ts' file to translate it and then compile to
'my_plugin_es.qm', it desn't work. Any idea how I have to write the menu
name in the 'my_plugin_es.ts' file?
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/translate-shortcuts-tp5222943.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
