[Qgis-developer] no more map ?
Sandro Santilli strk at keybit.net
Mon Sep 7 12:12:20 PDT 2015
On Mon, Sep 07, 2015 at 08:00:44PM +0200, Salvatore Larosa wrote:
> Il 07/Set/2015 19:44, "Sandro Santilli" <strk at keybit.net> ha scritto:
> > I'm running qgis from master after a long time and facing
> > a gui that does not show the map:
> >  http://strk.keybit.net/tmp/qgis-nomap.png
> How you done to load 2 layers and keep up the welcome page?
Right, that's the problem. I used "Add PostGIS Layer", selected
those two tables, and hit "Load". The commit id can be seen in
the titlebar. I hadn't tried to reproduce with that same commit,
and I could not reproduce (on first try) with current master.
Possible race condition ?
--strk;
