[Qgis-developer] [QGIS-Server] Relative paths and QGIS-Server
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Sep 21 18:29:31 PDT 2015
Hi René-Luc
Setting the QgsProject instance FileName will be fine. Just make sure it
is set at each request.
cheers,
Marco
Am 21.09.2015 um 15:07 schrieb René-Luc Dhont:
> Hi Devs,
> Hi Marco,
> I encounter some troubles with relative paths and QGIS-Server. For
> example, SVGMarker path and NETCDF datasource are not resolved in QGIS
> Server unlike in QGIS Desktop.
> To resolve relative path for SVGMarker, the class
> QgsSombolLayerV2Utils is used and it based on
> QgsProject::instance()->fileName().
> To resolve relative path for NETCDF datasource and other GDAL
> datasources, the class QgsMapLayer is used and it based on
> QgsProject::instance()->readPath( filename ).
> QGIS Server uses the QgsServerProjectParser to convert relative path
> to absolute path. This mean that it parses the project and update paths.
> To fixe this issue, we have 2 solutions :
> * Set the QgsProject instance FileName in the QgsServerProjectParser
> * Update QgsServerProjectParser::createLayerFromElement to resolve and
> update SVGMarker path and GDAL datasources
> Marco, I'dlike to have your point of view to fix it.
> Regards,
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
