[Qgis-developer] QGIS Master crashes on exit
Nyall Dawson nyall.dawson at gmail.com
Mon Sep 28 02:18:08 PDT 2015
On 28 September 2015 at 18:35, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi Casper,
> On Mon, Sep 28, 2015 at 10:04 AM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
>> Hi!
>> I’m using QGIS master x64 from OSGeo4W, and I’m experiencing crashes (with
>> minidumps) each time I exit QGIS (including if I just open and closes QGIS).
>> I don’t know how to extract a stack trace from the minidump (if it has one?)
>> and renaming the “.qgis2” folder doesn’t help.
>> I have just updated the my MASTER edition from OSGeo4W, based on revision
>> c7a3ea3, but I haven’t found a build date for that revision. The
>> “qgis-dev-bin.exe” has a modified date of September 16, 2015, but I would
>> expect it to be newer by now?
> the date of your revision is a couple of weeks ago (15 Sep), in the
> meanwhile a lot of fix have been pushed
> Please try a more recent revision, the crash should disappear.
Also try disabling plugins - a crash on exit can be caused by a bad plugin.
Nyall
> Thanks,
> -SL
>> I could open a ticket describing the problem, but I’m not sure where the
>> problem is? QGIS code or OSGeo4W builds?
>> Can any give me a hint?
>> Regards, Casper
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
