[Qgis-developer] Save Processing model outputs in SpatiaLite
Victor Olaya volayaf at gmail.com
Fri Apr 1 01:14:57 PDT 2016
Matteo
The ability to save to a DB is not dependent on the output itself, but
on the algorithm. Since models can have 3rd party algs, models are not
capable ,by default, of outputing to a DB. That can be fixed, and
yours is a very good idea. Can you open a feature request so we do not
forget about it? sounds like something interesting to work on at the
next HF :-)
Thanks!
2016-03-31 19:21 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi all,
> from the Las Palmas HF it is possible to save the QGIS algorithms of
> Processing in databases (both SL and PostGIS).
> I've seen that these option is not possible with other providers
> (gdal/ogr, SAGA...) and it is not possible with Modeler outputs even if
> in the Modeler one uses only QGIS algs.
> I think this is a super great feature.. Are there any plans to extend it
> also for other providers and for Modeler outputs?
> Thanks guys
> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
