[Qgis-developer] Proposal: removing Processing from plugins repo
Victor Olaya volayaf at gmail.com
Mon Apr 4 22:55:53 PDT 2016
I guess it's somehow my fault, since that is not documented
See here for the GRASS provider
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass/GrassAlgorithmProvider.py#L47
and here for the GRASS 7 one
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/Grass7AlgorithmProvider.py#L47
that should help understand
2016-04-05 7:49 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 05/04/2016 07:24, Victor Olaya ha scritto:
>> But that's an option in the provider. Some providers should be by
>> default disabled in Processing (for instance if they require an extra
>> setup -R- or there is another that is similar -GRASS and GRASS 7-).
>> For providers that come from a plugin, they should be active by
>> default, if they want users to have it enabled without going to
>> Processing and checking the correspodning box. So, in short, that is
>> an issue of the Provider plugin itself, since you can tell Processing
>> to have it enabled by default.
>> Hope this helps
> It does indeed, thanks again. Apparently some developers fid it
> difficult to grasp, as not all Processing plugins are enabled by
> default, nor even these who do not require special setup.
> Could you please pont me to an explanation of this, so I can help plugin
> writers to fix it?
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
