[Qgis-developer] Travis timeouts
Matthias Kuhn matthias at opengis.ch
Thu Apr 7 08:41:00 PDT 2016
On 04/07/2016 05:24 PM, Sandro Santilli wrote:
> On Thu, Apr 07, 2016 at 01:56:50PM +0200, Matthias Kuhn wrote:
>> We experience more travis timeouts (for qt4 builds) recently.
>> With respect to reducing false alarms to a minimum I think it would be
>> good to fix things.
>> I think there are two approaches, removing some components from the
>> build process, but I cannot see what.
>> Use ccache like we do for Qt5 builds. That would require recompiling
>> some deps (currently taken from ubuntugis) so they can be put into the
>> home directory, since for ccache we need to run container based builds.
>> Other ideas?
> Use docker to avoid deps builds ? Not sure if/how travis supports
> this. Pretty sure gitlab-ci does (in case you plan to add a mirror
> there).
Docker is supported but not on container based builds
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160407/3f6bb3d0/attachment.sig>
