[Qgis-developer] GRASS Plugin missing g.copy?
roy roy royroge at outlook.com
Mon Apr 11 00:27:16 PDT 2016
Thanks Stefan, very clear!
Il 10/04/2016 20:58, Blumentrath, Stefan ha scritto:
> Hi,
> I just tested the Browser in QGIS. It has indeed no "Copy" in the context menu, just "Rename",  "Delete" or New vector layer.
> However, Drag and Drop works fine. So if you want to copy a GRASS map, just drag it from the source to destination Mapset. Source and destination can be the same. If a map exists you are asked to specify a name...
> Hence, g.copy is not present in the GRASS plugin in QGIS.
> For me (QGIS 2.14.0, GRASS 7.0.3, OSGeo4W), g.copy starts also on the commandline. However, if you want to open the module GUI like that you have to run:
> g.copy --ui
> Cheers
> Stefan
> -----Original Message-----
> From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of roy roy
> Sent: 10. april 2016 16:11
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] GRASS Plugin missing g.copy?
> Il 10/04/2016 15:57, Blumentrath, Stefan ha scritto:
>> Maybe the browser provides that functionality... I guess it does...
>> Cheers
>> Stefan
> It does not but this is not the problem, i notice that i cannot start g.copy from GRASS itself using the shell, so it's not a "GRASS Plugin" issue but more a GRASS GIS issue,
> sorry and thaks anyway, roy
>> ________________________________________
>> Von: Qgis-developer [qgis-developer-bounces at lists.osgeo.org] im
>> Auftrag von roy roy [royroge at outlook.com]
>> Gesendet: Sonntag, 10. April 2016 13:06
>> An: qgis-developer at lists.osgeo.org
>> Betreff: [Qgis-developer] GRASS Plugin missing g.copy?
>> It seems that g.copy is not avalilable in GRASS Plugin, QGIS 2.14.1 is
>> this a "bug" or am i missing something?
>> thanks, Roy.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
