[Qgis-developer] [WIP] slider to zoom canvas like a magnifier
Alexandre Neto senhor.neto at gmail.com
Mon Apr 11 05:27:56 PDT 2016
This functionality is "offered" by ESRI with a different approach (not sure
if it's better or worst tho). The user can set/lock a reference scale to be
used in the map canvas, after that, the normal zoom tools will work just as
before (follow the cursor, drag to zoom a certain area, etc) but the
symbols will enlarge/reduce in proportion to "current scale" vs "reference
scale ratio". This provides a very good way to edit features and set styles
with the output scale in mind.
Vincent Picavet (ml) <vincent.ml at oslandia.com> escreveu no dia segunda,
11/04/2016 às 09:20:
> Hi,
> On 11/04/2016 09:02, Paul Blottiere wrote:
> > Announcing WIP for a slider providing a way to zoom the canvas, like a
> > magnifier does.
> > A use case is for example to facilitate the manual placement of small
> > labels.
> > A way to set up this tool is planned too (minimum, maximum and step).
> > Let me know if you have any comments.
> Note that this feature would also include a default global value, so
> that users on 4K+ screens can set it to avoid pixel-sized element being
> too small.
> Vincent
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160411/2a35d3e3/attachment.html>
