[Qgis-developer] Nightly & OS X Log Messages Panel - Python and QT
Thomas Endres endres.thomas at gmail.com
Thu Apr 28 09:54:02 PDT 2016
HI All,
I have been using the nightly builds for quite some time with OS X 10.11.4.
Couple of questions regarding errors I am seeing in the 'Log Messages
Panel':
1) Are QT Painter errors due to work with 3.0? Should they be disregarded
or reported? Lots of the following after a change in zoom level:
QPainter::begin: Paint device returned engine == 0, type: 3
2016-04-28T11:31:54 1 QPainter::setRenderHint: Painter must be active to
set rendering hints
2016-04-28T11:31:54 1 QPainter::translate: Painter not active
2016-04-28T11:31:54 1 QPainter::end: Painter not active, aborted
2) Ever since I can remember I have had the following appear in the 'Python
warning' tab:
2016-04-28T11:27:20 1
warning:/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/pkgutil.py:186:
ImportWarning: Not importing directory
'/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/mpl_toolkits':
missing __init__.py
file, filename, etc = imp.find_module(subname, path)
traceback: File "<string>", line 1, in <module>
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/qgis/utils.py",
line 326, in startPlugin
plugins[packageName] = package.classFactory(iface)
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/__init__.py",
line 29, in classFactory
from MetaSearch.plugin import MetaSearchPlugin
File
line 600, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/plugin.py",
line 33, in <module>
from MetaSearch.dialogs.maindialog import MetaSearchDialog
File
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/dialogs/maindialog.py",
line 43, in <module>
from owslib.csw import CatalogueServiceWeb
File
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/owslib/csw.py",
line 18, in <module>
from owslib.util import OrderedDict
File
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/owslib/util.py",
line 13, in <module>
import pytz
File
File
"/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/pytz/__init__.py",
line 29, in <module>
from pkg_resources import resource_stream
File
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py",
line 2813, in <module>
add_activation_listener(lambda dist: dist.activate())
File
line 686, in subscribe
callback(dist)
File
line 2813, in <lambda>
File
line 2346, in activate
list(map(declare_namespace, self._get_metadata('namespace_packages.txt')))
File
line 1942, in declare_namespace
_handle_ns(packageName, path_item)
File
line 1899, in _handle_ns
loader = importer.find_module(packageName)
Install or path errors on my end?
Thanks!
-tom
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160428/a9beb9db/attachment-0001.html>
