[Qgis-developer] Nightly & OS X Log Messages Panel - Python and QT
Thomas Endres endres.thomas at gmail.com
Fri Apr 29 08:24:39 PDT 2016
Hi Larry,
On Thu, Apr 28, 2016 at 10:30 PM, Larry Shaffer <larrys at dakotacarto.com>
wrote:
> Hi Thomas,
> On Thu, Apr 28, 2016 at 10:54 AM, Thomas Endres <endres.thomas at gmail.com>
> wrote:
>> HI All,
>> I have been using the nightly builds for quite some time with OS X
>> 10.11.4.
>> Couple of questions regarding errors I am seeing in the 'Log Messages
>> Panel':
>> 1) Are QT Painter errors due to work with 3.0? Should they be disregarded
>> or reported? Lots of the following after a change in zoom level:
>> QPainter::begin: Paint device returned engine == 0, type: 3
>> 2016-04-28T11:31:54 1 QPainter::setRenderHint: Painter must be active to
>> set rendering hints
>> 2016-04-28T11:31:54 1 QPainter::translate: Painter not active
>> 2016-04-28T11:31:54 1 QPainter::end: Painter not active, aborted
> This is a bug somewhere that is trying to set a property on a non-existent
> QPainter. That might be tricky to track down. Doesn't seem to be hurting
> anything, though.
Thanks for the info - for people smarter than I, here are the first lines
from the Qt tab in the 'Log Messages Panel' after launching a nightly QGIS
build and opening a project - the last 4 lines repeat a few hundred times:
2016-04-29T10:15:52 1 Object::connect: No such signal
QgsComposerItemComboBox::itemChanged( const QgsComposerItem* )
2016-04-29T10:15:52 1 Object::connect: (sender name:
'mWorldFileMapComboBox')
2016-04-29T10:15:52 1 Object::connect: (receiver name:
'QgsCompositionWidgetBase')
'mOverviewFrameMapComboBox')
'QgsComposerMapWidgetBase')
2016-04-29T10:15:53 1 QPainter::begin: Paint device returned engine == 0,
type: 3
2016-04-29T10:15:54 1 QPainter::setRenderHint: Painter must be active to
set rendering hints
2016-04-29T10:15:54 1 QPainter::translate: Painter not active
2016-04-29T10:15:54 1 QPainter::end: Painter not active, aborted
>> 2) Ever since I can remember I have had the following appear in the
>> 'Python warning' tab:
>> 2016-04-28T11:27:20 1
>> warning:/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/pkgutil.py:186:
>> ImportWarning: Not importing directory
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/mpl_toolkits':
>> missing __init__.py
> This is a system-installed module (not part of the QGIS packaging). You
> can just ignore the warning.
> You could try the following to get rid of the warning:
> sudo touch /System/Library/Frameworks/Python.framework/Versions/2.7/
> Extras/lib/python/mpl_toolkits/__init__.py
This did the trick! Now QGIS launches clean. I forgot to mention that I
already tried a re-install of the matplotlib Python package from
Kyngchaos.com which did not help.
Thanks again Larry - super appreciated!
-tom
> Just creating a blank __init__.py may do the trick. However, due to SIP
> security on 10.11.x , you may not be 'allowed' to create the file (even
> with sudo). If so, you can temporarily turn off SIP, create the file, test,
> then turn SIP back on [0].
> Alternatively, you could try installing matplotlib Python package from
> Kyngchaos.com or the official package somewhere on sys.path that will be
> picked up before the system install of matplotlib. I don't think this will
> really get rid of the warning, which may happen whenever the system paths
> are parsed.
> [0]
> http://arstechnica.com/apple/2015/09/os-x-10-11-el-capitan-the-ars-technica-review/8/
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> file, filename, etc = imp.find_module(subname, path)
>> traceback: File "<string>", line 1, in <module>
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>> line 326, in startPlugin
>> plugins[packageName] = package.classFactory(iface)
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/__init__.py",
>> line 29, in classFactory
>> from MetaSearch.plugin import MetaSearchPlugin
>> File
>> line 600, in _import
>> mod = _builtin_import(name, globals, locals, fromlist, level)
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/plugin.py",
>> line 33, in <module>
>> from MetaSearch.dialogs.maindialog import MetaSearchDialog
>> File
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/plugins/MetaSearch/dialogs/maindialog.py",
>> line 43, in <module>
>> from owslib.csw import CatalogueServiceWeb
>> File
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/owslib/csw.py",
>> line 18, in <module>
>> from owslib.util import OrderedDict
>> File
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/owslib/util.py",
>> line 13, in <module>
>> import pytz
>> File
>> File
>> "/Applications/QGIS_2.15-dev.app/Contents/MacOS/../Resources/python/pytz/__init__.py",
>> line 29, in <module>
>> from pkg_resources import resource_stream
>> File
>> File
>> "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py",
>> line 2813, in <module>
>> add_activation_listener(lambda dist: dist.activate())
>> File
>> line 686, in subscribe
>> callback(dist)
>> File
>> line 2813, in <lambda>
>> File
>> line 2346, in activate
>> list(map(declare_namespace, self._get_metadata('namespace_packages.txt')))
>> File
>> line 1942, in declare_namespace
>> _handle_ns(packageName, path_item)
>> File
>> line 1899, in _handle_ns
>> loader = importer.find_module(packageName)
>> Install or path errors on my end?
>> Thanks!
>> -tom
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160429/91c0e130/attachment-0001.html>
