[Qgis-developer] [QGIS] Using pixel as default units while defining layer style
ABALAIN, Pierre-Yves pierreyves.abalain at capgemini.com
Tue Aug 9 06:20:07 PDT 2016
This discussion seems to not resolve the issue.
Default units in SLF is pixel, and QGis always interpret it as millimeter.
Even using solutions mentioned in this discussion.
Regards.
Pierre-Yves Abalain
-----Message d'origine-----
De : Luigi Pirelli [mailto:luipir at gmail.com]
Envoyé : mardi 9 août 2016 11:42
À : ABALAIN, Pierre-Yves
Cc : qgis-developer at lists.osgeo.org
Objet : Re: [Qgis-developer] [QGIS] Using pixel as default units while defining layer style
a recend discussion about this issue
http://osgeo-org.1560.x6.nabble.com/SLD-export-not-compliant-due-to-unit-attribute-in-the-root-element-td5277807.html
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 8 August 2016 at 17:07, ABALAIN, Pierre-Yves <pierreyves.abalain at capgemini.com> wrote:
> Hello,
> I’m importing SLD in QGis Essen, and I note that unit for parameter
> (thickness for example) in setting layer styles are always in millimeter.
> But the application I used to export my SLD uses pixel as unit.
> Is there a parameter in QGis that allow me to change this default unit ?
> Regards.
> P.Y. Abalain
> This message contains information that may be privileged or
> confidential and is the property of the Capgemini Group. It is
> intended only for the person to whom it is addressed. If you are not
> the intended recipient, you are not authorized to read, print, retain,
> copy, disseminate, distribute, or use this message or any part
> thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
