[Qgis-developer] [Qgis-user] QGIS Crash Message
Tim Sutton tim at kartoza.com
Tue Aug 9 12:13:03 PDT 2016
Hi
> On 08 Aug 2016, at 1:32 PM, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 08-08-16 12:51, Tim Sutton wrote:
>> Hi
>>> On 08 Aug 2016, at 11:00 AM, Paolo Cavallini <cavallini at faunalia.it
>>> <mailto:cavallini at faunalia.it>> wrote:
>>> Il 08/08/2016 10:25, Richard Duivenvoorde ha scritto:
>>>> What about the idea to make the 'ini-file- based QSettings type the
>>>> default QSettings system for ALL Operating Systems?
>>>> In general I think it is just easier to instruct users to either throw
>>>> away or edit a file then fiddling in the registry..
>>>> QGIS3 would be a nice place in time to do this?
>>> Agreed, possibly the most unfriendly thing in QGIS.
>> I am +0 on this:
>> Con:
>> In windows we often used .reg files e.g. when doing training courses to
>> reset specific settings so that trainees all have the same state (you
>> can just double click on the .reg file to apply it). We also can use the
>> registry to enable things via NSIS installers - for example we make a
>> nightly build of the plugin (http://nightly.inasafe.org) which is
>> packaged as an NSIS installer that makes sure the plugin is activated in
>> the user's profile.
>> Probably we can do the same things by manipulating .ini files but the
>> current system is pretty easy.
>> Pro:
>> Using a unified configuration system on all platforms would be nice...
> I think having an option to use the registry on windows would be best
> then. As Régis also stated, in some enterprise environments it as
> apperently not doable to use the not-registry option...
> Then we have best of both worlds?
Probably we can add a setting in QGIS to indicate whether settings should be in native or ini style format [1]. Of course that is a bit paradoxical since it will need to read the settings to get the setting for reading the settings .... :-)
[1] http://doc.qt.io/qt-4.8/qsettings.html#QSettings-3
Regards
Tim
> Regards,
> Richard
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160809/f42bd51a/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160809/f42bd51a/attachment-0001.jpg>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160809/f42bd51a/attachment-0001.sig>
