[Qgis-developer] Is any work being done on problems with Qlonglong fields?
magerlin MAP at ramboll.dk
Mon Aug 22 04:44:25 PDT 2016
At least in Win7 64 bit many plugins either ignore Qlonglong fields or regard
them as text.
It is quite annoying to have to store attributes as Real to be able to work
in Qgis - especially since you have to add decimals as real 10.0
automatically is being converted to Qlonglong. And if you create a field as
short integer next time you open the shape file it is being regarded as
Qlonglong.
Post in Qgis User
<http://osgeo-org.1560.x6.nabble.com/Many-problems-with-qlonglong-Integer64-fields-td5264507.html>
I am unfortunately not a programmer so I cannot participate in solving
this....
Regards Morten
Currently using Qgis 2.16.1 (OSGeo4),
Windows 7, 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/Is-any-work-being-done-on-problems-with-Qlonglong-fields-tp5281463.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
