[Qgis-developer] Plugin repository wiki page
Anita Graser anitagraser at gmx.at
Wed Aug 31 08:34:10 PDT 2016
On Tue, Aug 30, 2016 at 9:26 PM, Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Il 30/08/2016 18:58, Anita Graser ha scritto:
> > Hi,
> > Is there anything on the plugin repo wiki page that we still need? I
> > reviewed it and it seems pretty much outdated:
> > http://hub.qgis.org/projects/quantum-gis/wiki/PluginRepository
> > It also mentions "trusted" users, which causes confusion with our
> > current effort to establish trusted plugin authors. (See comment
> > in http://gis.stackexchange.com/questions/203116/what-does-
> the-trusted-flag-mean-for-qgis-plugins)
> > I suggest deleting the wiki page.
> +1
> Thanks Anita for raising this.
​I'll move on and delete it. Bellow, you find the content for future
reference:​​
​This is the entry point for those interested in working on the plugin
repository. The plugin repository is a django application. The source code
for the application is hosted on github:
https://github.com/qgis/qgis-django
If you would like write access to the above repository, please contact Tim
Sutton (tim at linfiniti.com).
Note the repository was changed from a personal repository to a community
one - please note the new url above.
h2. The pieces
* http://plugins.qgis.org - the upload and download app
* http://hub.qgis.org the bugtracker for the plugins
* http://hub.qgis.org/projects/qgis-django/issues the bugtracker for the
webapp
h2. Version 1.0
This section lists wanted features for the first version of the plugin
repository. Once everything is on its place, we can probably switch from
the original repository now hosted at pyqgis.org and require all the plugin
developers to upload the plugins to the new repository. From that time, no
more public 3rd party repositories will be encouraged - everyone should be
happy to use the official repository :-)
For easy usage of the repository, a command line tool (supposedly a python
module) should be provided with qgis that will upload new plugin version,
given just the package file, changelog and username/password. Later we
could even create a plugin for convenience with simple GUI for instant
publishing.
List of views and actions in the plugin repository application:
* views for registered users:
** list my plugins
** plugin details with editing (remove incorrect upload, delete plugin, add
owner etc.)
* actions for registered users:
** add plugin / edit plugin
** upload new plugin version
* views for all users:
** list plugins (main page)
*** show either featured (default) or all plugins
*** show plugins of a particular user
*** sorting: recently added/updated, most downloaded
** show plugin details
** repository xml compatible with original repository
Notes:
* user authentication - osgeo LDAP should be used (no more new logins
please!), using HTTPS so that the passwords are not visible (see
http://packages.python.org/django-auth-ldap/)
* there is always one or more owners for a plugin, any owner of a plugin
can add new people as co-owners. Only owners are allowed to upload new
versions, edit or completely remove a plugin. If the owner of a plugin
disappears, a new owner could be assigned for the plugin by the admins
* download counts
** downloading of plugin packages should be redirected in order to
calculate download count directly (without accessing web server stats)
* featured plugins
** admins might want to mark interesting (and well behaving) general
purpose plugins as featured to make them more visible from the less
interesting ones
* trusted users
** a simple protection from malicious users: everyone is at the beginning
marked as untrusted, the uploaded plugins are not visible until an admin
doesn't review the code and mark the user as trusted. Plugins uploaded by
trusted users are immediately visible - this still leaves some space for
malicious users (first upload something good, get trusted, then upload
something bad), however we don't have resources to check all the updated
plugins. Malicious users - once detected - get blocked forever.
* plugin uploading: user should only select a file for upload and provide a
changelog - the rest should be handled on the server
* plugin versioning: for each plugin, the entire release history will be
kept. By default users will see only the last version. For plugins that
make distinction between development (experimental?) and stable versions,
there should be an option when uploading the plugin whether that is a
development version. The owner should be able to mark also manually which
version is the last stable and last development (experimental) version.
* upload checks
** check that the uploaded file has an acceptable size (e.g. < 1MB)
** check that the uploaded file is valid zip archive
** check that the plugin exists, user is owner of the plugin, this version
does not exist yet, ...
** parse plugin metadata and update the plugin details from it: nowadays
the plugins store metadata in __init__.py file, but it has been suggested
to migrate them to a separate text file (so that both repository and plugin
manager in qgis will have easier work). Of course a compatibility python
method should be kept in __init__.py file that would create the metadata
info from the text file. Syntax of the metadata file should be
user-readable and editable (i.e. no XML!), probably the best choice will be
the format used in "ConfigParser":
http://docs.python.org/library/configparser.html Python module.
Preliminary suggested table structure (incomplete):
* users: owner_id, name, mail, trusted  (connected to "LDAP":
http://packages.python.org/django-auth-ldap/?)
* plugins: plugin_id, name, description, last_version, last_update_time,
create_time
* plugin_versions: plugin_id, version, upload_time
* plugin_owners: plugin_id, owner_id
h2. Version 2.0
* categories/tagging of plugins - "django-tagging":
http://code.google.com/p/django-tagging/ or "django-taggit":
http://github.com/alex/django-taggit/
* user rating (no registration) - "django-simple-ratings":
http://github.com/coleifer/django-simple-ratings ?
* download charts (?)
* searching - "django-haystack":
http://github.com/toastdriven/django-haystack/ ?
* "ponies!":http://djangopony.com/
* for each plugin, a link to its original repo (default to a standard repo)
* for each plugin, a link to its bugtracker (for now, http://hub.qgis.org)​
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160831/844d7f57/attachment-0001.html>
