[Qgis-developer] [QGIS Server] How to share QgsPostgresSharedData between multiple QGIS instances
René-Luc Dhont rldhont at gmail.com
Thu Dec 22 04:15:48 PST 2016
Hi devs,
Do you have an idea  on a way to share a QgsPostgresSharedData between
multiple QGIS instances ?
The use case is for QGIS Server to manage a PostGIS layer with a text
primary key with WFS-T.
QgsPostgresSharedData is used to map int4 featureId with non integer
primary key. It is usefull for QGIS Desktop. But server side, if
multiple QGIS Server instances is used with 1 project, for performance,
each QGIS Server has it's own QgsPostgresSharedData.
I'd like to share it between multiple instances tohav the same feature
ids for same primary key.
Regards,
René-Luc D'Hont
