[Qgis-developer] Future of the GDALTools plugin
Mathieu Pellerin nirvn.asia at gmail.com
Fri Dec 23 08:29:30 PST 2016
Alex, there is one aspect where gdaltools plugin still surpasses
processing, namely the possibility of creating virtual rasters from
multiple files without having to load those in QGIS to begin with.
If that could be dealt with, I wouldn't look back to the plugin in a
hundred years :)
On Dec 23, 2016 23:23, "Alexander Bruy" <alexander.bruy at gmail.com> wrote:
> Hi all,
> some time ago I submitted a QEP about removing fTools and GDALTools
> plugins and replacing them with Processing [0, 1]. fTools plugin was
> removed,
> but GDALTools still here. IMHO it would be good to drop GDALTools in QGIS
> 3.0.
> Right now Processing offers same functionality as GDALTools plugin and even
> tools which are not available in GDALTools. Also it receives much more
> attention
> and bugfixes. For example, if a user creates with the field calculator
> a new column
> in a vector to be used for some operation within GDALTools, then this
> column
> is not recognized (but it is in the equivalent tool in Processing) and
> this is not
> only one problem.
> Are there any objections to remove GDALTools?
> [0] https://github.com/qgis/QGIS-Enhancement-Proposals/issues/54
> [1] http://osgeo-org.1560.x6.nabble.com/QEP-Dropping-
> fTools-GdalTools-in-favor-of-Processing-td5247519.html
> Alexander Bruy
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161223/3294cab7/attachment.html>
