[Qgis-developer] Testing new network analyses
Alexander Bruy
alexander.bruy at gmail.com
Mon Dec 26 05:24:19 PST 2016
Hi Paolo,
2016-12-26 10:51 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> thanks for this. got the issue: the travel cost parameter gets silently
> zeroed if I edit the default 0 value. If I first delete the 0,000000
> default value, then enter my param, it works fine. This is a general
> issue with Processing, and I believe it's a true bug of Processing (user
> inputs should never be discarded without consent).
Seems this is a general Processing bug and if I'm not wrong it worked fine
before parameters refactoring.
> BTW, what is the meaning of the `lower` polygon?
Actually service area defined with two boundaries:
* upper, which include closest to the starting point nodes/vertices
that not accessible
* lower, which include the most distant from starting point nodes/vertices
that still accessible
Alexander Bruy
