[Qgis-developer] Problems upgrading nightly in Ubuntu 14.04
DelazJ delazj at gmail.com
Fri Feb 12 07:17:59 PST 2016
Below the result of dpkg -s qgis-plugin-grass
Package: qgis-plugin-grass
Status: install ok unpacked
Priority: optional
Section: science
Installed-Size: 13300
Maintainer: QGIS developers <qgis-developer at lists.osgeo.org>
Architecture: i386
Source: qgis
Version: 1:2.13.0+git20160212+bcc8e2a+20trusty
Config-Version: 1:2.13.0+git20160202+8ca0ecf+20trusty
Replaces: qgis-provider-grass (<< 1:2.11.0+git20151002)
Depends: qgis (= 1:2.13.0+git20160212+bcc8e2a+20trusty),
qgis-plugin-grass-common (= 1:2.13.0+git20160212+bcc8e2a+20trusty),
qgis-provider-grass (= 1:2.13.0+git20160212+bcc8e2a+20trusty), libc6 (>=
2.4), libgcc1 (>= 1:4.1.1), libgdal1h (>= 1.8.0), libqgis-app2.13.0,
libqgis-core2.13.0, libqgis-gui2.13.0, libqgisgrass6-2.13.0, libqt4-svg (>=
4:4.5.3), libqt4-xml (>= 4:4.5.3), libqtcore4 (>= 4:4.8.0), libqtgui4 (>=
4:4.8.0), libstdc++6 (>= 4.1.1), grass-core
Conflicts: qgis-provider-grass (<< 1:2.11.0+git20151002)
Description: GRASS plugin for QGIS
 QGIS is a Geographic Information System (GIS) which manages, analyzes and
 display databases of geographic information.
 This plugin enables GRASS data access in QGIS.
Homepage: http://qgis.org/
thanks
2016-02-12 16:12 GMT+01:00 Jürgen E. <jef at norbit.de>:
> Hi DelazJ,
> On Fri, 12. Feb 2016 at 16:02:11 +0100, DelazJ wrote:
> > Sorry. I tried a sudo apt-get install -f:
> > Décompactage de qgis (1:2.13.0+git20160212+bcc8e2a+20trusty) sur
> (1:2.13.0+git20160202+8ca0ecf+20trusty) ...
> > dpkg: error processing archive
> /var/cache/apt/archives/qgis_1%3a2.13.0+git20160212+bcc8e2a+20trusty_i386.deb
> (--unpack):
> >  tentative de remplacement de « /usr/bin/qgis.bin », qui est la version
> détournée de « /usr/bin/qgis » (paquet : qgis-plugin-grass)
> > dpkg-deb : erreur : le sous-processus coller a été tué par le signal
> (Relais brisé (pipe))
> Which version of qgis-plugin-grass is installed?
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160212/254b83b2/attachment.html>
