[Qgis-developer] Begging for some fixes before LTR release
Andrea Peri aperi2007 at gmail.com
Tue Feb 23 06:05:32 PST 2016
I guess that activating the contectual legend in the canvas, also in
the composer the not visible layers should disapperaing.
Is this ok for your usage ?
A.
2016-02-23 14:22 GMT+01:00 DelazJ <delazj at gmail.com>:
> Hi developers,
> At less than a week for the release of the second LTR version (QGIS 2.14),
> I'd like to draw your attention on two main issues that are not set as
> blockers but I'd beg you to solve them:
> #13575 (http://hub.qgis.org/issues/13575): adds all the available layers to
> the legend in print composer instead of just adding those that are visible
> in the map canvas. Not set as blocker (it should imho) but AFAICT this
> behaviour was introduced in LTR 2.8 and it's not optimal at all when you
> have a very big project.
> #13418 (http://hub.qgis.org/issues/13418): it makes preset visibility pretty
> unusable with print composers in (large) project with multiple print
> composers. For any change you do to a preset, you need to manually echo it
> in the map composer properties if you want your maps to be up to date. It's
> just unmanageable in, once again, big project (since 2.10 if I'm not wrong).
> I know that there are currently some blocking issues, maybe more sensitive
> but these ones just block me (and surely many other people) in my daily
> work. I'd be grateful to you if someone can give a look to these issues.
> Thanks for the fixes :) and thanks for the great work you're doing with
> QGIS.
> DelazJ
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andrea Peri
qwerty àèìòù
