[Qgis-developer] Compiling QGIS with GRASS Plugin
Marco Bernasocchi marco at opengis.ch
Fri Feb 26 09:01:10 PST 2016
Nope just pass -DWITH_GRASS=ON to cmake.
Ccmake is a great way to see what switches you can use.
Ciao
On 26 February 2016 17:48:05 CET, m roy <royroge at outlook.com> wrote:
>Ciao Marco,
>is it mandatory to use ccmake? because i compiled with "regular"
>cmake, make, make install ...
>Il 26/02/2016 17:44, Marco Bernasocchi ha scritto:
>In ccmake there with_grass iirc
>Ciao
>On 26 February 2016 17:32:37 CET, m roy
><royroge at outlook.com><mailto:royroge at outlook.com> wrote:
>Hi,
>i'm learning to compile QGIS in Ubuntu 14.04,
>managed to compile QGIS 2.14 and installed
>in a custom dir with make install,
>with:
>export LD_LIBRARY_PATH
>QGIS starts (by the way the 2.14 splash screen image is HUGE :))
>with some warnings and one error:
>ERROR 4: `/initrd.img' not recognised as a supported file format.
>but it seems to work, anyway i cannot find the GRASS Plugin, is there
>some other variable to set so that QGIS can see it ?
>libgrass*7.so<http://7.so> are present in the lib/qgis/plugins/
>directory so i do not
>think there is a compile issue (?)
>thanks ! Roy.
>________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
>List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>-- Marco Bernasocchi (mobile). OPENGIS.ch<http://OPENGIS.ch> -
>berna.io<http://berna.io> - 27summits.ch<http://27summits.ch>
>_______________________________________________
OPENGIS.ch - berna.io - 27summits.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160226/b1a851e6/attachment.html>
