[Qgis-developer] Geometry modifiers for labeling
Andreas Neumann a.neumann at carto.net
Wed Jan 13 06:23:39 PST 2016
Hi Matthias,
You mean I should then set the data-defined label position to the start
and the endpoint of the line?
Yes - this kind of works, but I would have to calculate the
orientation/direction of the first and last segment of the line myself.
But we are getting closer to solving this issue ;-) ...
Andreas
On 13.01.2016 15:01, Matthias Kuhn wrote:
> Good to know.
> So that should work find with my previous recommendation of using
> "Placement" -> "Data Defined"?
> On 01/13/2016 02:59 PM, Andreas Neumann wrote:
>> Hi Matthias,
>> You can just add several rules that all apply at the same time (e.g.
>> two times an empty rule only bound by map scale ranges).
>> In the placement options use one time "above line", and the other time
>> " below line".
>> This works fine. See screenshot at
>> http://www.carto.net/neumann/temp/label_multiple_times.png
>> The workaround with font-markers from Matthieu works fine, but it is
>> ugly that the labels can be up-side-down.
>> Andreas
>> On 13.01.2016 14:45, Matthias Kuhn wrote:
>>> Hi Andreas
>>> On 01/13/2016 01:59 PM, Andreas Neumann wrote:
>>>> Hi Matthias,
>>>> Yes - with the new rule-based renderer we can label a line several
>>>> times
>>>> - e.g. have one label above the line and another with another label
>>>> text
>>>> below the line.
>>> I can't find the possibility to label the same feature twice, only
>>> different labeling rules for different features.
>>> But I guess you can use "data defined placement" instead of "above" or
>>> "below"?
>>> Matthias
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160113/ef703543/attachment.html>
