[Qgis-developer] issues with intentation test
Alexander Bruy alexander.bruy at gmail.com
Thu Jan 14 08:41:21 PST 2016
Hi all,
Not sure if this is only my local issue.
Seems indentation test is a bit unstable and sometimes gives different
results on local machine and Travis. For example, I received two emails
about broken builds and from logs I see that this caused by failed indentation
test. But on my machine this test passes and prepare_commit.sh does
not find any issues. Also runing manually autopep8 on problematic file
leaves it unchanged.
Alexander Bruy
