[Qgis-developer] DbManager - new sqlite PRAGMA index_list returns more columns than expected
kimaidou kimaidou at gmail.com
Tue Jan 19 01:45:41 PST 2016
Hi all,
I just proposed a PR for fixing this issue :
https://github.com/qgis/QGIS/pull/2696
related to
http://hub.qgis.org/issues/14110
Thanks for review and merge.
2016-01-15 11:29 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> Some users reported a bug in DbManager. When you connect to a database,
> and then click on one layer, the plugin tries to fetch information about
> the layer and its indexes.
> The method "getTableIndexes" situated in line 371 of the file
> "db_manager/db_plugins/spatialite/connector.py"expects to get 3 fields from
> the sqlite method "PRAGMA index_list"
> In recent version of SQLite, though, this method now returns 5 fields, for
> example
> sqlite> pragma index_list(geo_parcelle);
> 0|idx_geo_parcelle_ogc_fid|0|c|0
> 1|geo_parcelle_voie_idx|0|c|0
> 2|geo_parcelle_comptecommunal_idx|0|c|0
> This leads to a Python error :
> File
> "/usr/share/qgis/python/plugins/db_manager/db_plugins/spatialite/connector.py",
> line 371, in getTableIndexes
> num, name, unique = idx
> ValueError: too many values to unpack
> A change has been made in sqlite code, see
> https://github.com/mackyle/sqlite/commit/efa3207797a6ff4eb6a514fad5c99cf67c056492
> Then a bug fix has been added for retro-compatibility if index_info , but
> not for index_list
> https://github.com/mackyle/sqlite/commit/53555d6da78e52a430b1884b5971fef33e9ccca4
> We need to backport a bug fix, if it is done in DbManager
> I have opened a bug in the hub, since I have not been able to find a
> corresponding issue.
> I will try to debug it quicky, or have someone already worked on it ?
> Cheers
> Michaƫl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160119/b7f57f46/attachment.html>
