[Qgis-developer] Adding new provider for QGIS
Paolo Cavallini cavallini at faunalia.it
Mon Jan 25 23:05:36 PST 2016
Il 26/01/2016 00:14, Nyall Dawson ha scritto:
> Hi David, (and cc'ing back in qgis-dev)
> When you open a pull request against the main QGIS master repo, the
> automated test suite (https://travis-ci.org/qgis/QGIS) will kick in and
> run a test build and run all the existing unit tests to avoid
> regressions. It will also run some "meta" tests, checking code quality
> and adherence to the code standards.
Hi David,
your PR will have to be inspected by core QGIS devs. As it is very
specific, you may be lucky that someone will get interested, and revise
it for free. If you need to speed up the process, you may consider
sponsoring this work directly.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
