[Qgis-developer] Can I change QgsAbstractGeometryV2::fromWkb signature ?
Sandro Santilli strk at keybit.net
Tue Jan 26 08:12:24 PST 2016
On Tue, Jan 26, 2016 at 04:53:20PM +0100, Matthias Kuhn wrote:
> On 01/26/2016 04:45 PM, Sandro Santilli wrote:
> > On Tue, Jan 26, 2016 at 01:52:41PM +0100, Matthias Kuhn wrote:
> >> I would add a second method with size param and deprecate the current one.
> >> This way we can prepare our own code and remove the dangerous method in 3.0
> > Consider that QgsGeometry::fromWkb() already takes a size parameter:
> > https://github.com/qgis/QGIS/blob/master/src/core/geometry/qgsgeometry.h#L141-L145
> > It's just not passed over to the QgsAbstractGeometryV2::fromWkb.
> > Is the "internal" call still to be considered part of the API ?
> Why not?
> Is there a problem with the proposed approach? I would say it is quite
> safe and future proof.
Well, I wouldn't call it "safe".
It is a way to still allow "unsafe" code to run.
It's not even "cheap" as a measure: if every single method has to be
considered part of the API, it'd take a lot of code duplication to keep
the deprecated version alive.
QgsAbstractGeometryV2::fromWkb is re-implemented for each and every
subclass. Each subclass ends up calling WkbPtr which is currently also
not bound-checking, so we'd need another method duplication there.
Each of the deprecated methods would need to call the safe version
with an arbitrarily choosen "length" (max int, I guess?).
Is there a way to tell what's part of API and what's not ?
--strk;
