[Qgis-developer] Adding new provider for QGIS
Marco Bernasocchi marco at opengis.ch
Tue Jan 26 23:35:17 PST 2016
Hi David,
Ideally you should work as follows:
- Fork the qgis repo on github
- in your fork create a feature branch (you can also work in _your_
master, but feature branche are much more clean)
- keep _your_ branch up to date with QGIS master (this will save you a
lot of headaches when merging)
- when done make a pull request [1] on QGIS master (base fork:
qgis/QGIS, base: master) with your own branch (head fork: dadler/QGIS,
compare: your_feature_branch). if you don't see all four fields, click
on compare across forks.
this pull request will get travis involved automatically
hope it helps
ciao
Marco
[1] https://github.com/qgis/QGIS/compare?expand=1
On 26.01.2016 23:43, David Adler wrote:
> I'm afraid I'm relatively new to Git - I have mostly used SVN with GDAL
> and GeoTools.
> I created a fork off github.com/qgis/qgis onto my
> github.com/dwadler/qgis environment.
> The branch is set to master.
> When I clicked on New Pull Request, it said they were the same and
> didn't do anything.  Your note stated that this will kick off the
> automated test suite.
> Should I be doing a git clone to my development system, creating a new
> branch, putting the new/modified code in it, commit and push back to
> github? Then do the pull?
> I didn't think I could do a push to github - wouldn't this attempt to
> update the QGIS master?  It isn't clear how Travis gets in the loop.
> For testing, wouldn't QGIS need a live connection to a DB2 database?
> Please excuse the novice questions.
> David
> On 1/25/2016 6:14 PM, Nyall Dawson wrote:
>> Hi David, (and cc'ing back in qgis-dev)
>> When you open a pull request against the main QGIS master repo, the
>> (<https://travis-ci.org/qgis/QGIS>https://travis-ci.org/qgis/QGIS)
>> will kick in and run a test build and run all the existing unit tests
>> to avoid regressions. It will also run some "meta" tests, checking
>> code quality and adherence to the code standards.
>> So that's the first step - open your PR against QGIS master (not
>> against your fork), and see how this goes. Then you basically keep
>> revising your branch and pushing to github and for each new push
>> Travis will retest until you get a green light.
>> The next step is adding new tests to cover your work. Without tests it
>> *will* break in some future QGIS release, so that's why testing is
>> mandatory for something like this. The provider test also runs a bunch
>> of complex cases against each provider to ensure that they correctly
>> handle a bunch of corner cases, so it will help ensure that your
>> provider is well behaved and stable.
>> Here's some other provider tests which are good models to copy from:
>> https://github.com/qgis/QGIS/blob/master/tests/src/python/test_provider_shapefile.py
>> https://github.com/qgis/QGIS/blob/master/tests/src/python/test_provider_spatialite.py
>> (Note that both also implement additional tests specific to that
>> provider, eg testRepack for shapefiles). The ms-sql provider test is a
>> good example of a minimal test, which only implements the things
>> required for the generic provider test (although you could also omit
>> the enableCompiler/disableComplier methods if you haven't implemented
>> an expression compiler for db2 yet). Then you'll also need to include
>> relevant test data -
>> see <https://github.com/qgis/QGIS/tree/master/tests/testdata/provider>https://github.com/qgis/QGIS/tree/master/tests/testdata/provider
>> for what's expected in the test files,
>> eg <https://github.com/qgis/QGIS/blob/master/tests/testdata/provider/testdata_mssql.sql>https://github.com/qgis/QGIS/blob/master/tests/testdata/provider/testdata_mssql.sql.
>> Hope that helps!
>> Nyall
>> On 26 Jan 2016 10:05, "David Adler"
>> <<mailto:dadler at adtechgeospatial.com>dadler at adtechgeospatial.com> wrote:
>> > I'm not clear on what the "automated CI" is or how one runs is.
>> > We did a fork and pull to our fork to do the development.
>> > I'm still a bit hazy on setting up and running the tests.  Does a
>> database need to be operational in order to run the tests?
>> test_provider_mssql.py doesn't look like it does much.
>> > On 1/25/2016 4:24 PM, Nyall Dawson wrote:
>> >> On 26 Jan 2016 07:57, "David Adler"
>> >> > We would like to add a DB2 provider to QGIS so that QGIS users
>> can access spatial tables on DB2 for LUW and DB2 for z/OS.
>> >> > We have implemented and tested much of this based on an existing
>> database provider.
>> >> > What is the mechanism to have this reviewed and approved?
>> >> Open a pull request on github, and let the automated CI run its
>> checks over the code.
>> >> Tips to get things reviewed/merged faster:
>> >> - Make sure all your API additions are correctly documented
>> >> - Include unit tests. At a minimum a new vector provider needs a
>> test which inherits from ProviderTestCase. See
>> tests/src/python/test_provider_mssql.py for an example. This ensures
>> that the provider behaves consistently with what QGIS expects from a
>> vector data provider.
>> >> Nyall
>> >> > This email has been checked for viruses by Avast antivirus software.
>> >> > https://www.avast.com/antivirus
>> >> > _______________________________________________
>> >> > Qgis-developer mailing list
>> >> > Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> >> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > This email has been sent from a virus-free computer protected by Avast.
>> > www.avast.com <http://www.avast.com>
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> www.avast.com
Marco Bernasocchi
OPENGIS.ch - berna.io - 27summits.ch
