[Qgis-developer] Build failure following qt creator setup instructions
Andrea Aime andrea.aime at geo-solutions.it
Sun Jul 3 06:15:14 PDT 2016
On Sun, Jul 3, 2016 at 2:37 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Andrea,
> On 07/03/2016 02:18 PM, Andrea Aime wrote:
> >   File "/home/aaime/devel/qgis/scripts/pyuic-wrapper.py", line 26, in
> > <module>
> >     import qgis.PyQt.uic.pyuic
> > ImportError: No module named PyQt.uic.pyuic
> > Any clue as to why the build is failing?
> Do you have (an old version of) QGIS installed via package manager?
Yes, QGis 2.8.6 Wien, as part of the standard packages of Mint.
Are you suggesting to remove it?  Was kind of hoping to have two
versions side by side, one stable for day to day work, and one built fresh
to test SLD generation changes.
> > I've also tried following the Ubuntu instructions
> > inj https://github.com/qgis/QGIS/blob/master/INSTALL,
> > in that case ccmake fails to find qwtpolar, which does not seem to be a
> > package included in Mint 18
> > (I've found libqwt5-qt4 and installed it, but it did not help)... does
> > one has to hand build this package
> > in order to build qgis?
> You can cmake it with -DWITH_QWTPOLAR=OFF or -DWITH_INTERNAL_QWTPOLAR=ON.
Thanks, I'll try
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160703/9d479fd4/attachment.html>
